another dex3 question...
If you want one of the better Dexron rated fluids for your manual trans look into Redline D4 ATF. It is a synthetic and carries a GL-4 gear rating. Much better than any conventional dex fluid. It is also an ester based ATF and as such can handle extreme temperatures. I have used it for years in my T-56. The only drawback is you have to in most cases order it and it can be expensive.
Further I do not believe your problem is fluid related. Most all Dexron fluids are very tight with respect to the specs given for the fluid. Most have a Vis @ 100°C, cSt of about 7.5-7.6}. Friction modifiers and such will also be very similar between brands. If the fluid was a DEX III and you changed it without a change in the grinding action then that usually means its mechanical in nature.
