Different Gear ratios
Old Jan 29, 2010 | 10:56 PM
Egg1456's Avatar
Default Different Gear ratios
I am wanting to get my t56 rebuilt by tick shift but i want to drop the 6th gear ratio down to .62 or near and i was wondering where i would be able to get a different 6th gear with the lower ratio.
Old Jan 30, 2010 | 01:57 AM
the_merv's Avatar
Veteran: Air Force
You wont be able to do just 6th..if you can find a Cluster and the Gears you can do both 5th and 6th to a lower Gear. Why not just change out the Gears in the Diff..that would be cheaper.
Old Jan 30, 2010 | 07:20 AM
85MikeTPI's Avatar
This thread has some of the relevant info for you on changing ratios:
https://ls1tech.com/forums/manual-tr...gear-swap.html
Old Jan 30, 2010 | 02:56 PM
Egg1456's Avatar
I know you can just do 6th. Because i like my 4.10s for drag, not soo much for gas mileage, soo if u change 6th u get the best of both worlds
Old Jan 30, 2010 | 03:26 PM
the_merv's Avatar
Veteran: Air Force
^^Have you torn a T56 down?
Trust me you can't do just 6th..it's both 5&6, or none.
Old Jan 30, 2010 | 03:33 PM
Egg1456's Avatar
i forgot to put 5th and
Old Jan 30, 2010 | 03:44 PM
hivoltagedriver's Avatar
The M12 version of the T56 (Z06, CTS-V, GTO) had the gear ratios that you are looking for. We also got a steeper 2.97 1st gear. Maybe just as cheap to find a M12, and drop to a 3.73 or 3.90 rear gear.
Old Jan 30, 2010 | 10:27 PM
Egg1456's Avatar
well im really just looking for someone who sells the gears soo i can have tick shift install it when i get mine rebuilt, cheaper i think in the long run. And i like the 4.10s i get 25mpg with the cam and gears and tune i have just would like to see it in the 30s
Old Jan 31, 2010 | 08:23 AM
85MikeTPI's Avatar
How is taking 6th gear from 0.50:1 to 0.62:1 going to increase your millage from 25 to 30mpg ?
Old Jan 31, 2010 | 08:36 AM
eseibel67's Avatar
Yes, you are going the wrong way. Stock 5th gear is 0.74:1.
Old Jan 31, 2010 | 08:54 AM
spaz1's Avatar
^^ what he said?????
From What i've read the 5 and 6 gear tooth count is the same on mm6 and the mn12 transmissions, it's the input shaft that has a differnt tooth count and changes the ratios.
Old Jan 31, 2010 | 09:18 AM
the_merv's Avatar
Veteran: Air Force
As I mentioned above..if he changed the Rear Gears it prob would work out better for what he wants..and cheaper..
Old Jan 31, 2010 | 11:32 PM
Egg1456's Avatar
i thought 6th was. the .74
Old Jan 31, 2010 | 11:36 PM
bww3588's Avatar
nope, 5th is .74 and 6th is .50
Old Jan 31, 2010 | 11:39 PM
Egg1456's Avatar
well crap, dont think there is much lower you can go than that
Old Feb 1, 2010 | 05:33 AM
the_merv's Avatar
Veteran: Air Force
Nope..lol
