Master cylinder line Help!!!!!!
Old Dec 24, 2003 | 05:07 AM
02Z28's Avatar
Default Master cylinder line Help!!!!!!
How do you remove the steel braided line that runs to the master cylinder inside the transmission?
Old Dec 24, 2003 | 06:54 AM
Camaroholic's Avatar
Grab a pair of mid size flat blade screwdrivers...
See where the line goes in to the tranny? Push the line in *hard* in to the tranny and hold it there. Should 'slip' in a little.
Take one (or two) of the screwdrivers and push the little white plastic collar (that you see on the tranny side of things) towards the tranny. Once it's slipped in a little, pull out on the line. Should pop right out.
-Andrew
