will my tranny break if.........
I pan to go to the track with some sticky tires and really run it,like 5k clutch dumps
Should i get a stronger bellhousing?
and do i need to worry about anything in the tranny breaking like input shaft or output shaft??
The T56 is a pretty damn strong transmission, as long as its in good condition I don't see it being a problem. I wouldn't worry about the bellhousing either, I don't think a blowproof bellhousing is necessary unless you're turning some really high RPM's or running single digit times.
For the bellhousing, I went with the Quicktime but won't have it on until next weekend and probably won't have the car running again for another few weeks. The Quicktime was the overwhelming consensus of the board over the McLeod.
