installing MSD Shift Light
For the power, you dont want power all the time, but only when your car is on. For this I connected mine to the ignition wire. This would be pin assignment #19 on your car, it will be a pink wire (or something close to that color). Splice that wire going into the pcm and hook up your power wire to it.
Now for the easy part. Hook the ground up anywhere you see other stuff grounded. On some pcm's there is a screw that holds in the pcm, you can use that, or any other place you see wires grounded to the car.
I know these instructions probably suck and you are wondering, wth is he talking about, but if you need more help and some pics check out this link.
http://www.raptorperformance.com/98_...stallation.htm
Keep in mind that is for a 98 install, so the pin assigments are different that yours which I gave you above, but the pics should help.
