Clutch Issues!!! Please help!
Old Mar 7, 2010 | 10:51 PM
santizz5588's Avatar
Default Clutch Issues!!! Please help!
Okay so I know this might sound like old news to some of you but I am have lots of issues with my clutch lately. First off I replaced clutch and flywheel with Z06/LS2 setup. I also replaced slave and master. There is DOT 3 fluid in the system right now. The issues I am having are when the air temperature is below 50 degrees. When its below 50 out my clutch pedal is very lazy (slow to return even sometimes sticks halfway up) and also extremely soft which causes some hard shifting. When above 50 degrees the car drives likeva dream with perfect pedal pressure perfect pedal firmness throughout travel snd excellent shifting (like a hot knife through butter). So what could the issue be here?
Need for drill mod?
Fluid change to DOT 4?
Good bleed with some fresh DOT 3 or DOT 4 fluid?
Please any input is helpful heree!!!!!
Old Mar 8, 2010 | 02:54 PM
bumppp
Old Mar 9, 2010 | 08:43 AM
please someone anyone!
Old Mar 9, 2010 | 08:47 AM
Blk2kSS's Avatar
Although I’ve never had this exact issue before I would say that the drill mod is always a good idea and I’m running dot 4 in mine. Not really sure if this helps but no one else has chimed in so I figured id say something.
Old Mar 9, 2010 | 10:02 AM
thanks for the input!
Old Mar 9, 2010 | 07:57 PM
Can anyone shed some more light on this issue?
Old Mar 10, 2010 | 02:29 PM
still need some help with thisss
