1st Gear Problem
Old Jan 3, 2004 | 10:28 PM
redline2k's Avatar
Default 1st Gear Problem
My 02 SS recently quit going into first gear unless it is pulled back into second gear first. Can anyone point me in the right direction to fix this problem. If it helps it has 25k miles a spec aluminum fly wheel and a spec carbon stage 3 clutch with about 10k on them both. the hydraulics are still stock gm
Old Jan 3, 2004 | 11:07 PM
JMBLOWNWS6's Avatar
It is the slider plates mine does that too no big deal opps syncro
Old Jan 4, 2004 | 08:38 AM
Bugsquawsher's Avatar
Slider Plate????
Sounds like your first gear Synchro assembly is Burred up.
Gotta get inside the tranny to replace some parts
Tom
Old Jan 4, 2004 | 10:01 PM
JMBLOWNWS6's Avatar
Originally Posted by Bugsquawsher
Slider Plate????
Tom
Your the one that told be that tom ???????
Old Jan 5, 2004 | 07:53 AM
Its called a syncro Assmebly
I thought you were talkin about the Guide Plate.
The syncro assembly is not a plate at all, It looks more Like a wheel.
Tom
Old Jan 6, 2004 | 01:43 AM
JMBLOWNWS6's Avatar
Ah ok got ya my bad
