ls7 clutch
Old Apr 14, 2010 | 12:07 PM
USCGMEATHEAD's Avatar
Default ls7 clutch
which one is better?
http://sdparts.com/details/scoggin-d...enter/sdls7ack
http://sdparts.com/details/scoggin-d...center/sdls7ck
Old Apr 14, 2010 | 12:29 PM
ArcticMissile's Avatar
One has the upgraded aluminum flywheel and ARP bolts. The other does not. I believe that extra 100 bucks is better spent elsewhere. My personal experience with aluminum is that it's overrated and steel holds up to wear and tear better.
Old Apr 14, 2010 | 12:36 PM
bigti99a's Avatar
+1. i just got the steel kit from sdpc. i am very happy with the ls7 so far. good street clutch for cars with down to earth power numbers. if you have 500+hp you may want to look at something else.
Old Apr 14, 2010 | 12:41 PM
Z28_LT1's Avatar
Option 2.
Mine's still sitting in my closet untill I get a slave.
Old Apr 15, 2010 | 09:54 AM
bamaballa205's Avatar
500rwhp or 500fwhp
Old Apr 15, 2010 | 09:58 AM
99ssleeper's Avatar
since the z06 is supposedly 505 fwhp, id say fwhp.
Old Apr 15, 2010 | 11:52 AM
k5383's Avatar
This might be a stupid question....But that flywheel will work on a LS1 correct?
I kept reading somewhere that it is a different flywheel or something rather?
Old Apr 15, 2010 | 11:55 AM
99ssleeper's Avatar
you need to use the ls2 flywheel with the ls7 disc and PP, which is how sdpc packages them. not the ls7 flywheel.
Old Apr 15, 2010 | 12:38 PM
You can't use an LS7 clutch on a stock LS1 flywheel. You need the entire LS7 clutch package that includes clutch, pressure plate, and flywheel.
Old Apr 15, 2010 | 06:21 PM
ibex37's Avatar
i just installed that same package, you need the LS2 flywheel and the ls7 clutch disc and pressure plate. some other things to consider would be a new pilot bushing or bearing. i went with a bushing just because i dont like the idea of running bearings with out a way to lube them. also you may want to look at a new slave and master. i would go with a steel flywheel, the aluminum flywheel will not hold up like a steel flywheel.
Old Apr 15, 2010 | 07:12 PM
natesscamaro's Avatar
Default ls7 clutch
i bought my car a litle over two months ago and when going for 2nd gear the clutch let go i prdered up a new clutch only to find out when i tore it down that the car had a ls7 clutch in it i dont know what my hp numbers are i would guess around 450 wheel hp but the spring center on the disk compleatly broke out
Old Apr 15, 2010 | 07:21 PM
01 Bad Mutha F*****'s Avatar
Have the LS7 clutch with the steel flywheel. Had Speed Inc install a tick m/c at the same time. Seems to be a nice unit, had it for 2500 miles so far.
Old Apr 16, 2010 | 01:39 AM
Raptor_WS6's Avatar
i love my ls7 clutch kit i just installed. my last dyno was 403rwhp but now i should be right around 430+ and it holds up fine
Old Apr 18, 2010 | 06:55 PM
How long have you been running it?
Old Apr 18, 2010 | 08:12 PM
_JB_'s Avatar
Another LS7 here. I've been running it for almost two years, no problems.
Old Apr 19, 2010 | 12:20 AM
Raptor_WS6's Avatar
i got it used and put it on last week, i bought this one from this thread
https://ls1tech.com/forums/manual-tr...ever-dies.html
