3rd gear problem
Old Apr 20, 2010 | 01:54 PM
jamiesls1's Avatar
Default 3rd gear problem
I can shift into all gears except third. When the car is off it goes in smooth and perfect yet when I drive it will not go. Slow speed..... high speed.... neutral doesn't matter wont go in. I have read the other posts and nothing seems to fit what I have. The slave is brand new...brand new clutch line....brand new 1 inch master. Still doesnt work.....brand new ls7 clutch and ls2 flywheel...still doesn't work. Please help.
Old Apr 20, 2010 | 02:11 PM
85MikeTPI's Avatar
Broken 3rd gear blocker ring on synchro.
Old Apr 20, 2010 | 04:37 PM
jamiesls1's Avatar
Are you pretty sure and if so how much does that cost to have fixed?
Old Apr 20, 2010 | 04:54 PM
jmd's Avatar
jmd
Post
Quite likely if it's blocked out the teeth of the gear and slider are ground down.
If the gear and the synchro are replaced, over $200 in parts plus labour / supplies.
Old Apr 20, 2010 | 11:16 PM
jamiesls1's Avatar
Is there anymore tests I can do to make sure that is the problem because dropping the tranny isn't the funnest thing in the world.
Old Apr 21, 2010 | 11:17 AM
jmd's Avatar
jmd
You tested it. Drop the trans.
