Help need with Ram install
Jonathan Hays
There's no 'magic' with an adjustable system. It only allows you to adjust the point where the pedal sits. If your pedal comes all the way up, yet the clutch is engaging just off the floor, it's obvious that you're not pushing the throwout bearing far enough. That's what happens when air gets in the system.
It's not difficult to make your stock master "adjustable". I've got a stock adjustable master running my Ram VDS 910. It merely adjusts the resting spot of the pedal. Mine is fine, though I am upgrading to the McLeod so that I can guarantee full disengagement at 7000+ RPMs.
If your pedal isn't coming all the way up, you need to make it adjustable so that it can. You can do this simply - with a die (to thread the master's rod), a threaded tube, and a couple of nuts. That's all the adjustable master is.
Cut the rod an inch from the pedal end, thread both sides about 3/4" in, use the threaded tube to hold the two pieces together, and use nuts to jam them and lock them in place.
No real need to spend $250+.
-Andrew
-Andrew
Notice how the front piece (where you see my hand) is the adjustable portion. This adjusts the pedal height.
You are correct - the bore is larger than stock, and it will push more fluid. But I still think you have an air problem.
Where does your pedal sit when the clutch pedal is released? Is it all the way up?
-Andrew
-Andrew
