I hear the Mcleod is a good set-up, and the new design SPECs are good too, but in my opinion RAM is the best out there. RAM has the BEST customer service BAR NONE! RAM has two different ways to go: just a clutch(pressure plate, disk, flywheel, and throw-out bearing) OR the VDS system(pressure plate, clutch disk, throw out bearing, flywheel, brand new slave cylinder, and brand new ADJUSTABLE MASTER CYLINDER). No matter what anyone says(especially SPEC), you NEED an adjustable master cylinder. The adjustable master will extend the distance the slave can travel allowing for complete disengagement of the clutch disk AND it will make it possible to make the point of engagement on the pedal adjustable. On a stock clutch or an aftermarket clutch without the adjustable master; the pedal gets closer to the floor as the clutch wears and eventually when the clutch is completely shot the pedal will be useless. With the adjustable master you can bring the pedal height back up to where it was when the clutch was new. Most of the people out there that have clutch problems like grinding while shifting or not being able to shift is caused by either A) hydraulics not bled properly- air in the line or B) lack of a quality ADJUSTABLE master cylinder or C) malfunctioning slave cylinder. Personally, I would get the RAM 402/910 VDS system. The 402 pressure plate holds GREAT and only makes for a little more pedal pressure then stock(at first you will think it's a lot harder to push the clutch in but you will get used to it really quickly). RAM has several different clutch disks available too, for different intentions: 300 series, 6000 series(6130), and 900 series(910) . The 300 series is basically a stock type replacement: soft engagement and low torque with NO poweradders! The 6130 is a GREAT disk in my opinion(this is what I have). The 6130 bites hard. When the disk begins to engage from a stop, like leaving from a stop sign, with little throttle you will get some chatter(where the car seems to shake a bit). The chatter is from the aggressive disk biting into the flywheel, its completely normal and can be limited with a bit more throttle, and if you plan to swap in some 4.10s that will help A LOT. I have 315 BFGs on my SS and I can bark the tires easily shifting to 4th. My 3rd gear shift is as hard as my WS6's 2nd gear(it has an original design SPEC stage 3 carbon). I don't just get a chirp shifting to 3rd, I spin the tires. I DO NOT POWER-SHIFT, I only speed-shift. When I was at my local track(crap track by the way) I managed to get a 1.6 60ft on 26x10.5 ET STREETS at 12PSI and when I grabbed 2nd I broke the slicks loose and spun through 2nd, shifted to 3rd and continued to spin until 5000rpm and it hooked...I was shocked at how good the clutch was grabbing. The 6130 sin't good for any power-adders though! When RAM released this set-up(6130 was the launch disk they used) there were several people out there that had an issue of the disk fusing(melting) to the flywheel. There were MAINLY two main reasons for this: A) improper installation B) use of a power adder(mainly N2O). Ram didn't know the nitrous would cause this at first; so they were upgrading the customers to the new 910 for free or for a huge discount- parts only. The 910 is also very aggressive but will handle poweradders just fine. You will need the billet flywheel with either the 6130 or 910 because they will chew up the stock flywheel. I plan to upgrade to a 910 eventually, but not till my 6130 wears out. There are several guys out there that have gotten over 20k out of their RAM clutches. Call either Mikey at Rapid Motorsports or Allan at Futral Motorsports. They both will give you ALL the info you want/need and have GREAT prices. You will also want someone with LS1 clutch experience to install this. Good luck!
