A-4 To T-56
Old Jan 11, 2004 | 09:27 PM
LILBLKBIRD's Avatar
Default A-4 To T-56
I WANT TO CONVERT MY A-4 CAMARO TO A T-56, IVE NEVER SEEN ANY ONE DO IT BEFORE BUT I IMAGINE IT COULD BE DONE SINCE IVE SEEN A MANUAL CONVERTED TO AUTO BEFORE. IF ANY OF YOU GUYS KNOW HOW I COULD DO THIS OR COULD OFFER SOME ADVICE THEN I WOULD APPRECIATE IT. THANKS.
Old Jan 12, 2004 | 01:22 AM
Fierce-LS1's Avatar
this is what you're going to need.
1) Transmission
2) Clutch and Flywheel
3) Cross-Member/Mounting bracket
4) Hydraulics Master /Slave Cylinder
5) BellHousing
6) M6 Pedals + M6 Console
7) Shifter + ****
It's basically a bolt in. All you have to do is reflash the computer. It's been done plenty of times before.
hope that helps
Old Jan 12, 2004 | 03:33 AM
LILBLKBIRD's Avatar
thanks Im looking into doing it in the near future I guess my best bet is to find a wrecked f-body and just swap the parts.
Old Jan 12, 2004 | 08:00 AM
Bugsquawsher's Avatar
1) Transmission
5) BellHousing
7) Shifter + ****
hope that helps
You will also Be Cutting a Hole for the Clutch master, and The shifter.
I did one on an LT1 a couple of months ago.
Also you need to make sure the Torque arm bracket on the tranny is there.
they are different from A4 To T56.
A boot for the shifter also.
Old Jan 12, 2004 | 09:57 AM
HotRod68Camaro's Avatar
someone told me that the wiring harness is different for the T56 trans
Old Jan 12, 2004 | 11:29 AM
Fierce-LS1's Avatar
The wiring harness does not necessarily have to be changed. There's some wiring to the process though. You can either reflash the pcm or put in the m6 pcm.
