Tailshaft bushing replacement write-up?
Old May 27, 2010 | 11:09 AM
ThoR294's Avatar
Default Tailshaft bushing replacement write-up?
I have a t56 that I need to replace the tailshaft bushing on before I put it in my car. I was wondering if anyone has a write up on how to do it... Im very nervous about touching this transmission... lol Thanks!
Old May 27, 2010 | 01:27 PM
85MikeTPI's Avatar
I think that should give you your answer.... ;-)
You need to pull the tailhousing off. Knocking out the old bushing is easy, but you need special tools (or GREAT luck/care) to install the new one without damaging it. Finally clean and reseal the tailhousing back onto the trans. Not a major task, but not a DIY/first-timer's task either...
My $0.02
Old May 27, 2010 | 04:57 PM
ThoR294's Avatar
I work on cars everyday, but never take apart transmissions lol. I just like having some kind of instructions, makes me feel better haha. TY for the info. Hopefully this will eliminate a vibration ive been chasing
Old May 27, 2010 | 08:03 PM
jmd's Avatar
jmd
You can drive one in and hope it doesn't distort. If it does, don't ask questions, just get or borrow the right tool:
https://ls1tech.com/forums/manual-tr...g-trouble.html
I never had a problem w/ any GM 27 spline output tailhousing bushings in autos or manuals. One T56 tailhousing made me a fan of the tool.
Old May 28, 2010 | 09:45 AM
ThoR294's Avatar
has anyone had this bushing cause a bad driveline vibration?
Old May 28, 2010 | 10:19 AM
85MikeTPI's Avatar
Anything's possible,but typically the bushing is an affect, not a cause of vibration. An out-of-balance driveshaft, bad u-joint, bent/twisted outputshaft, pinon, etc. cause the vibration and the bushing takes a beating by the slip-yoke.
Old May 28, 2010 | 10:55 AM
TDP's Avatar
TDP
I had a piece of pipe modified & machined to the correct diameter, and it works perfectly. I think I paid 20 bucks or so. It is used with the shop press. I found that it is best to use a press as opposed to hammering it in. This way you will avoid damaging the top part of the bushing.
Old May 29, 2010 | 08:11 AM
ThoR294's Avatar
2 diff driveshafts, one of which was balanced, new u joints. rear rebuilt. etc.
I had 2 diff transmissions in my car. One is rebuilt and thats the one im going to put the new bushing in.... ugh.
and ty for the info guys... imma put the bushing in the "rebuilt" trans (got the rebuilt one off ebay) and see if it changes my vibration
