help with trans please
Old May 31, 2010 | 06:48 PM
d2camaro's Avatar
Angry help with trans please
i bought a hays street strip clutch and does not say clutch side or flywheel side any where and im trying to get it back together tonight.so does flat side go against flywheel or the raised side.
Old Jun 3, 2010 | 08:41 AM
samb0ness's Avatar
i've never seen the hays setup, but it's probably the flat side. there should only be one way for it to go...
Old Jun 3, 2010 | 09:28 AM
raven154's Avatar
On a single disk, generally the flat side goes to the flywheel andt he hub goes toward the trans. The hub will usually hit the flywheel if installed incorrectly.
