Cruise Control issue?
Old Jun 20, 2010 | 09:12 PM
ozzman98's Avatar
Default Cruise Control issue?
so after i did my swap a while ago my cruise control never worked. been wondering why.. all wires are plugged in an all cables are on. fuses are good. not sure wat it could be. its a stock T56. any suggestions would be appreciated. thanks
Old Jun 20, 2010 | 10:06 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
Probably same as mine. I have the same problem. I figured out there is a switch at the top and bottom to tell the car where the clutch pedal is. With the Tick MC it never reaches the top which tells the computer to shut the cruise off when the pedal is down, and the bottom is to start the car. I haven't had time to fix it yet but i was thinking of zip tying the top switch down. I just don't know how it will work to start the car when it thinks the pedal is all the way up and down.
Old Jul 17, 2010 | 02:12 PM
ozzman98's Avatar
ok. i didnt know that. i will have to look into it. an i just bypassed the bottom one to start the vehicle so i dont have to push the clutch in everytime to start it. thanks a lot.
