T-56 Questions...
There are no Hydraulics inside the T56
But you do fill it will ATF.
Not gear lube.
Maybe he's talkin about the Slave cylinder.
But no atf goes in there .
LT1 car had the slave cylinder on the outside of the tranny.
LS1 cars have the slave cylinder that goes around the input shaft, inside the bell housing.
Does that help ya any?
Tom
Don't really know
The external one is easier to service.
I'm guessing that Gm went to the internal one as an upgrade.
Fewer moving part.
Not sure if one is better than the other.
Not that it really matters
if you are this tranny in your 2000 you would have to use the internal.
