White Lithium Grease???
Old Jan 16, 2004 | 04:30 PM
01PewterWS6's Avatar
Talking White Lithium Grease???
On the installuniversity site it says to use white lithium grease on the input shaft of the transmission(clutch swap). Would this work better than axel grease?
Thanks
Wade
Old Jan 16, 2004 | 08:03 PM
emarkay's Avatar
yes.
It's a different base, and less chance to contaminate things, and bette heatand pressure tolerance - last thing you want is grease on the facings.. In a pinch, I'd use ball joint grease before using axle/bearing grease, but I'd get a tube of lithium!
Old Jan 17, 2004 | 01:37 PM
wrencher's Avatar
wrencher
I like lithium or a synthetic grease for those type of area's.
Old Jan 17, 2004 | 05:20 PM
66ImpalaLT1's Avatar
I used a light coat of synthetic axle grease on the pilot bearing and splines. I hope thats ok because i'm not pulling it apart again, its a pain in the neck.
