need some help
Tranny,bell housing, Clutch and pressure plate, fly wheel, Bolts for the clutch,Pilot bearing , Master cylinder w/Ubolt and slave cylinder and throw out bearing , Torque arm bracket,(the one on the A4 is Different than the T56, Shifter, Clutch and break pedal assembly , console, shifter Boot, Some connectors to swap over things like Reverse lights, Reverse Lockout, Start Kill for when the cluth isn't to the floor and one for when its all the way up for The Cruise control, Speedo, and I'm sure theres more than I'm forgetting.
Its quite a task.
