Shift fork conversion possible?
Old Jul 13, 2010 | 11:43 PM
wrencher's Avatar
wrencher
Default Shift fork conversion possible?
I know might be a more work than it's worth type endeavor
But... wonder if you can swap out the shift fork from a T6060 to a MN6/MN12 T56.
Might be another upgrade possible to tighten up the shift rail section???
The pads look close to the same size. I dont know anyone heard of this or tried it?
Old Jul 14, 2010 | 12:10 AM
jmd's Avatar
jmd
anything is possible. If anything is off, you may as well just go custom at that point though.
for each fork / synchro, are the following the same:
pad thickness at the slider groove
L pad to R pad distance
shift interlock groove at the fork link
if yes, shift interlock groove groove to slider groove
etc.
Old Jul 14, 2010 | 01:02 AM
wrencher's Avatar
wrencher
Na I'm just talking easy upgradable idea's that are simple. If it tightens it up why not ! ?
It's not worth a bunch of machining a bunch custom parts for a negligable improvement.
Old Jul 14, 2010 | 09:55 AM
thesource's Avatar
Pads should be the same size. Why would you want that fork over the iron version that is easily available for the T56?
Old Jul 15, 2010 | 12:33 AM
wrencher's Avatar
wrencher
For the 1/2 & the 5/6 rail the intergral cast in shift links on the T6060 forks might tighten it up a bit.
I agree keep the steel 3/4.
