flywheel locating pins
Looking straight at the flywheel, the pins are to the right of the bolt holes. The clutch pressure plate on the other hand the holes for the pins are on the left of the bolt holes. wtf?
The pressure plate is stamped LUK with a part number of 85478-4A19C. Anyone have any info. I've verified the flywheels GM part number of 12554130N and that checks good.
Possible to redrill the pins on the flywheel or just drill the pressure plate?
