Light feeling clutch?
Old Aug 3, 2010 | 05:19 PM
1979rs/z28's Avatar
Default Light feeling clutch?
I have a spec 3 right now and have been getting caught in stop and go driving lately and with it being very stiff its killing me.
I know about all the different brands of clutches and the ls7 but I'm afraid it wont be enough (car made low 400's at the wheel) but i need a light feeling clutch which one?
Old Aug 4, 2010 | 02:09 AM
Brief Encounter's Avatar
Twin Disc
Old Aug 4, 2010 | 05:25 AM
maxspeed05V's Avatar
LS7 may or may not last depending on your driving style, and how often the car will see the track.
I have one and it feels great, but as far as lasting only time will tell.
Old Aug 4, 2010 | 07:13 AM
1979rs/z28's Avatar
I'm normally daily driving, it really only sees the track maybe once a year. I've been looking into the ls7 plus the car is still on a 10 bolt so there will be no hard launches either.
Is a twin disc seriously a light feeling clutch? I'll look into that too, never drove one.
Chronicle's Avatar
If you are looking at serious upgrades in the quadruple-digit range, get a twin disk. I recently put a Monster Stage 3 in my car and after 1000 miles the pedal has about as much resistance as it did with the stock clutch.
Old Aug 4, 2010 | 07:23 AM
1979rs/z28's Avatar
I'm not thats why I figured the twin was overkill.
I really need to find someone around with a stage 2 or 3 monster to feel it for myself, I'd hate to swap one in and it be just as stiff as my spec.
Old Aug 4, 2010 | 07:26 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If you want a stock feeling clutch, you probably need to get a stock clutch. The LS7 fits that bill, and would probably hold the type of driving you do.
I run an RPS twin - it isn't stock pedal light (especially with the Tick master cylinder that has a larger bore), but it isn't far from it. There's a reason why you see high horsepower cars coming with twins straight from the factory (the ZR1 Vette comes to mind) - well...at least the ones that still require you to shift. They have excellent driving manners without requiring leg press pedal pressures.
Unless you plan on adding a whole bunch more power, though, a twin would be overkill. So back to my original recommendation - get an LS7 clutch and be done with it.
Old Aug 4, 2010 | 11:48 AM
Matt@SNLPerformance's Avatar
The Monster Level 2 and Level 3 fell just a fraction heavier than a stock clutch. Either will work fine with your power level, it just depends on how you will be driving the car.
Give me a call at the shop and we can see what model fits you best.
Matt
817-750-2000
Old Aug 4, 2010 | 12:05 PM
SPEC-01's Avatar
1979...let me know when and where you bought this clutch? Do you know if it is one of the older 11" units or if it is a newer 12" unit. Let me know and I will be happy to assist you further. Thanks!
PS. what Master are you using on the car?
