Need recommendations for a lightweight flywheel
I'm also looking for a matching clutch, needs to hold ~400rwhp or so. I do drive the car to the track so I don't want a particularly heavy clutch pedal feel...
TIA!
I'm by no means an expert when it comes to clutches but I have been through a couple and I like my twin the most thus far. There are singles that will more than get the job done but if you track the car a lot, I think you would like the way the twin winds up fast. It makes rev matching a brease and for the most part have zero chatter so its nice to drive in traffic.
I run an Exedy twin that weighs in at 35lbs and I run that in a 4000lb CTS-V. I dont have any problems in traffic and the clutch has performed flawlessly. It does take some getting used to being so light, but its not bad and mines in a heavy car.
If this is going into a 1/4 car, you may want a single with a little more weight behind it.
