transmission line up hints
I thought I had it good but tried aligning again and it was fine.
Unless u have issues with the spigot. Did u replace it?
Twin plates need to be perfectly aligned. is it a twin?
Set the alignment tool in place (in the disc, inserted to the pilot too)
Rock the tool up and down.
Stop about in the middle of the range of motion (may not be perpendicular to the flywheel)
Tighten a PP bolt enough to secure the disc.
Tighten the bolt on the opposite side and tighten all in a proper star pattern.
Verify the tool slides in and out with ease.
If it doesn't, start over.
If you have an old input, those work better than the plastic tools.
