Old Apr 25, 2016, 05:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Torque Specs Clutch/Flywheel
Old Sep 15, 2010 | 11:40 PM
Hulkamania's Avatar
Default Torque Specs Clutch/Flywheel
Hey guys can anybody tell me what the torque specs are on the clutch and flywheels are on these LS1's?
Old Sep 16, 2010 | 12:34 AM
BarneyMobile's Avatar
Flywheel bolts = 74 lb ft
Pressure plate bolts = 52 lb ft
I would torque the bolts in stages. GM says for the flywheel to torque the bolts to 15 lb ft on the 1st pass then 37 on the 2nd pass followed by the full 74 lb ft.
Old Mar 25, 2020 | 11:46 AM
LSDevo's Avatar
are these TTY?
Old Mar 31, 2020 | 01:33 PM
chrysler kid's Avatar
Originally Posted by LSDevo
are these TTY?
No, however I strongly reccomend using new flywheel bolts every time
At the very least when re using flywheel bolts I add a 4th torque rating to be sure the old bolts do not break. However you can clearly see the bolt distortion to the edge of the bolt
Flywheel : 18ftlb - 36ftlb - 52ftlb - 74ftlb
