Traction control not functioning???
Old Sep 18, 2010 | 09:40 PM
chadnol10's Avatar
Default Traction control not functioning???
can somebody help me and i apologize if this is the wrong forum, but i took my car to get tuned and they put it on the dyno. Now my traction control is always turned off. what could have ruined it on the dyno? the switch doesn't work but its not a bad switch. is there a module that the dyno could have ruined? the TCS light is always on in the dash now.
Old Sep 19, 2010 | 08:02 AM
wssix99's Avatar
Save the manuals!
The car's computer turns the TCS on every time the car starts. The switch just commands it off.
You probably have a bad speed sensor, or something like that at the wheel. You should definitely get it looked at as your ABS system could have problems also. (they use the same sensors)
First you need to get the brake system scanned for codes. They will indicate where the problem is.
Old Sep 20, 2010 | 06:03 PM
chadnol10's Avatar
bump!!!
Old Sep 20, 2010 | 07:12 PM
Spartan7's Avatar
I had the same problem when I got mine dynoed and accidentally left the traction control on. It will take a couple ignition cycles to reset, and the light should go away.
Old Feb 12, 2011 | 07:32 PM
chadnol10's Avatar
any body know what the problem actually is here? has to be the TCS motor or module right?
Old Feb 12, 2011 | 11:11 PM
wssix99's Avatar
Save the manuals!
Not necessarily. Did you scan the brake system for codes? The car's systems should be able to tell you what is going on.
Old Feb 14, 2011 | 01:58 PM
chadnol10's Avatar
system is not telling me anything!!! any thing else i can check?
Old Feb 14, 2011 | 02:06 PM
vette0009's Avatar
You need to pull the code 1St
I just fixed mine Thanks to this forum *
Yes your ABS is probably not working either
Old Feb 14, 2011 | 07:09 PM
Deviant LS1's Avatar
Is your ABS INOP, TCS OFF and BRAKE light on or just the TCS OFF light. If all three are lit then you need an ABS scanner to pull the codes. If just the TCS OFF light is on then the only thing I know that can cause that is turning down the traction control severity in the PCM down to 0. In the PCM you can change how much the TCS controls wheel spin on scale of 0-10. If you put it to 0 it will leave the TCS off and your light will come on.
Old Feb 14, 2011 | 07:34 PM
wssix99's Avatar
Save the manuals!
What are you using to check for codes?
Old Feb 15, 2011 | 12:57 PM
MikeMs01TA's Avatar
If you look in front of the driver's side axle, there should be a wire harness plugged into the body of the car for your wheel sensors. If you had an idiot strapping your car down to the dyno, they threw the strap over the wires and pulled the connector out. That's what happened to mine last time I was on a dyno. Luckily nothing was broken.
Old Feb 15, 2011 | 09:16 PM
chadnol10's Avatar
ABS works fine
Old Feb 15, 2011 | 09:17 PM
chadnol10's Avatar
must be something in pcm i guess then
Old Feb 15, 2011 | 11:34 PM
wssix99's Avatar
Save the manuals!
Take it back to your tuner. If they broke something, they will be able to read that from the codes. If they didn't break something, then they screwed up some programming.
