t56 yoke length
Old Sep 24, 2010 | 07:15 PM
the450r's Avatar
Default t56 yoke length
search is not helping me find dimensions. i have a yoke the correct spline not sure if i need a longer one. its 3.75" long.
Old Sep 25, 2010 | 08:20 AM
85MikeTPI's Avatar
Yoke's are typically measured from the U-joint centerline, to the end of the splined shaft.
A stock yoke will be 5.5" from C to end, which gives about 3.75" of "slip" tube.
http://www.drivetrainspecialists.com...ip-yoke-1.html
Has various lengths, U-joint versions, steel versions, etc..
Most custom Driveshaft vendors have instructions on measuring length and speak to the amount of slip tube typically needed. Most of the time unless you have alot of suspension travel, a stock length yoke will suffice.
Old Feb 21, 2023 | 07:04 AM
zachand799's Avatar
hoping somebody could chime in… got a rcsb chevy 2wd swapping the v6 for an animal of a v8 with turbo, got a t56 need a yoke i was told i’ll need to have driveshaft shortened probably but what size yoke will i need? or do I need to also call the place doing the custom work and ask them for specifics ?
thanks, Zac
