no reverse
Old Sep 26, 2010 | 11:30 AM
STFU racing's Avatar
Default no reverse
Just did a new clutch/throwout/slave in my car and when I put everything back together, there is no reverse. If I push it a little harder, it will grind but I don't want to have to force anything. All my forward gears shift and engage properly.
Basically I'm posting to make sure this couldn't be a common issue with a simple fix before I pull the transmission because I think it's a bad synchro...Let me know what your opinions are and I'll go from there.
Old Sep 26, 2010 | 01:44 PM
68 SS's Avatar
Code:
Did you plug the reverse lockout up after having the trans out
Old Sep 26, 2010 | 04:47 PM
raven154's Avatar
Originally Posted by 68 SS
Code:
This wont make any difference if you're getting a grind. I would bleed it again before I pulled it back out though.
Old Sep 26, 2010 | 06:14 PM
all plugs are reconnected...I'll re-bleed it just in case but if it's grabbing all other 6 gears would it be reverse specific or does reverse just need more throwout to engage than the others??
Old Sep 26, 2010 | 09:39 PM
raven154's Avatar
Generally if its just happening in a single gear, its gear related. However; bleeding the clutch is the easiest and cheapest cause its pretty much free and I have seen it fix more than one "trans wont go into gear problem."
Old Sep 26, 2010 | 10:40 PM
Counted Out's Avatar
I'm having the exact same problem. Here's my thread on it:
https://ls1tech.com/forums/manual-tr...-symptoms.html
What year is your car? I've narrowed the problem down to my slave and/or master cylinder. Go under your car and see if the plastic strap has broken on your slave cylinder. Mine hasn't, which means that the slave rod isn't extending all the way for some reason. I'm guessing your having a similar problem. I'm also guessing it's slightly harder to get into the other gears, maybe not much harder, but noticeably harder.
I've tried EVERYTHING to fix it, including replacing the slave. I think the problem is that I replaced the slave and master cylinders separately. If you look in the GM Service Manual, it only refers to the master/slave as coming out as one complete unit. Replacing just the slave can cause problems getting it to completely bleed. I'm going to try to buy a prebled GM slave/master set.
Old Sep 27, 2010 | 03:58 PM
thanks, I'll check for that plastic sleeve. Trans work is definitely my weak point on knowledge. it's a 2000. all the other gears seem perfect, no trouble shifting what so ever. That's why I'm assuming maybe gears specific..
thanks for all the help
