WheelHoppin
Old Jan 28, 2004 | 07:32 PM
Jakessm6's Avatar
Default WheelHoppin
I recently put a spec stage 3 in my lightly modded 99 ss m6...
Since then ive had incredible wheel hop..! Will an adjustable torque arm help?
Any ideas?? Thanks
Old Jan 28, 2004 | 08:36 PM
thechef's Avatar
Moderator
i would do lower control arms first that cured my wicked wheel hop problems
Old Jan 29, 2004 | 03:57 PM
pontiac's Avatar
i have bad wheel hop to and have lower control arms and relocating bracket and it still does it.. i need some help to.
Old Jan 31, 2004 | 02:26 AM
Sudz's Avatar
if you have relocating brackets and lcas, next option would probably be a panhard rod.
Old Jan 31, 2004 | 10:32 AM
Jakessm6's Avatar
damn chevys!!!
Old Jan 31, 2004 | 02:18 PM
camarossdn's Avatar
A torque arm should eliminate the wheel hop, if you already have the lower control arms.
Old Jan 31, 2004 | 02:37 PM
Jakessm6's Avatar
Thanks for the help..Ill try lower control arms, w/tourqe arm, and see the
difference, what brand of each should I get, or does it matter...
-Jake
Old Jan 31, 2004 | 03:14 PM
thechef's Avatar
Moderator
depends on what you want, adjustable or not
they are all pretty much the same
Old Feb 1, 2004 | 04:59 PM
pontiac's Avatar
has anyone seen or used the traction bars that jegs sells for our cars tey bolt on to the rear end the where the lca blot on. let me know what yall think
