Need Help!!!
Old Jan 29, 2004 | 12:53 AM
adamB's Avatar
Default Need Help!!!
I just had a Spec 2 clutch installed with a flywheel and a new slave cylinder. But new problems have arose. Now it won't go into reverse when the car is on. The first time I jumped in it worked after a couple of tries. Now it won't work. The only way to get it into reverse is to turn the car off and put it into gear. I don't think it is the lock out cylinder because with the car on, it will go all the way over and halfway up into gear. But then it just stops and won't budge. Feather the clutch out a little and it still won't budge. Then with the car off, i push the shifter over and up with no problem.
I was thinking it might be the stop on my ripper needs to be slightly adjusted. One of my friends thought the hydraulics might need to be bled again. What do you guys think??
Old Jan 29, 2004 | 03:15 AM
Blown98's Avatar
Hey im kinda having that prob right now but mine is just hard to get it to go over to the base of the gear, if you get any help let me know.
