brass shifter cup question So I stuck one of those brass shifter cups in today. I also changed the fluid from B&M non-syn. trick shift to Synchromesh. Its hard to move the shifter to reverse now? Is this normal, a side effect of the shifter cup? I don't have to hulk it in, but there sure is some force to overcome to the right side to get up into reverse. Took it for a quick spin, like it so far! I had no problems taking the plastic one out, as well it had worked itself out! Came right out with the shifter, no wonder this thing has felt sloppy for awhile. |
Did the bronze cup slip in easy, or did you RTV it in? The one's I've done have almost been press-fit and I've pulled the offset lever out to install the bronze cup on the bench.. I would say that your rev blocker ring is probably worn, and the fluid change has made it show itself. You might want to go back to a good quality dexIII non-synth and give it another test.. |
RTV? It didn't go in very easily. I put a folded up shop rag under the lever to keep potential debris from getting in the transmission and whacked it in with a block of wood and hammer. |
I put a bronze shifter cup and hurst billet in my car at the same time, and i noticed it was a bit harder to get in reverse. not sure which is to blame. fluid is valvoline dex III. not too many miles. |
© 2024 MH Sub I, LLC dba Internet Brands
