almost finished need help!!!
Old Oct 13, 2010 | 08:20 PM
ats5424's Avatar
Default almost finished need help!!!
I built a gen 1 sbc for my 95 formula m6 and i cannot find a pull type clutch for my car. I've tried putting my lt1 flywheel on and doesn't fit, the lt1 clutch doesn't fit on the 153 tooth sbc flywheel I bought. I also purchased a 10.5 in zoom clutch for that flywheel and the pressure plate is a push type and I cannot find a pull type for it. I'm so close to being finished guys and i need some help thanx..
Old Oct 13, 2010 | 10:40 PM
jmd's Avatar
jmd
1) spec clutch link --------->
2) change "Choose an application type" to "Conversion Application."
3) choose "2pc chevy rear main V8 to LT1 T56"
The SC66S allows you to use an LT1 T56 clutch with it behind your 85-down SBC / 2pc rear seal BBC. It is neutral balance (fits 350, 327, 396, 427 and others; a 400 or 454 would require rebalancing of the flywheel.)
