1st to 4th gear t56 disable
Old Nov 2, 2010 | 05:47 PM
babrown18's Avatar
Default 1st to 4th gear t56 disable
I'm a owner of a 06 Cts-v and I hate the first to 4th gear feature they put in the car to save gas if you get to a high enough rpm. In the v it kicks In at 2500 rpm and I want it disabled. Is there any way this can be done?
Old Nov 2, 2010 | 05:50 PM
thesource's Avatar
Yes it can be disabled.
Old Nov 2, 2010 | 06:00 PM
babrown18's Avatar
Does it have to go to a tuner?
Old Nov 2, 2010 | 06:05 PM
098z28's Avatar
u need to buy a skip shift eliminator
Old Nov 2, 2010 | 06:49 PM
raven154's Avatar
It can be done with cags eliminator or a tuner can do it. If you are going to have your car tuned, disable it then. If you plan on keeping the car stock, you can pick up cags! all over the place. I have one in my car, its just plug and play. It was the first thing I installed when the car was stock.
Old Nov 2, 2010 | 11:20 PM
jb98camaro's Avatar
i think i paid like 15 bucks or so on an ebay skip-shift eliminator and it works perfect
heres the only one i found on ebay for a cadillac
http://cgi.ebay.com/ebaymotors/Cadil...item53e46c81ca
all depends if its worth the money to disable it..
i think but im not sure but with the f bodys you can just put a resistor across the two pins but idk about a cadi.. not as nice of a way but my buddy did it and has no problems..
