Best shifter!
Old Nov 15, 2010 | 12:40 PM
99FormulaM6r's Avatar
I love my MGW.
To answer the last question, the factory Hurst and aftermarket Hurst are completely different, with the aftermarket Hurst usually being much better almost all applications.
Old Nov 15, 2010 | 01:05 PM
MR2liter's Avatar
I've thought about trying the mgw but decided against it since it has no shift stops. Anyone with the mgw damage your trans from power shifting?
Old Nov 15, 2010 | 01:44 PM
ramairetransam's Avatar
Mgw problems what ?
Old Nov 15, 2010 | 02:43 PM
The MGW shifter doesn't have shift stops (some, such as the aftermarket Hurst do), but rather uses the transmissions internal stops (like the stock shifter I believe)
I don't know if it would be a problem, I think the only issue that could come up would be from powershifting to 3rd or 4th as that's the fork that usually takes the most abuse. If it ever becomes a problem (which I can't imagine it being for most users), you can always upgrade to a steel fork over the factory aluminum. I posted a question about this a while back (you can search for the thread) and I was told not to worry about it.
Old Nov 15, 2010 | 10:37 PM
ffrh911's Avatar
I think I'm going to try out the mgw. If I don't like the feel of it in the first few miles I can send it back right?
Old Nov 15, 2010 | 10:47 PM
ffrh911's Avatar
For the mgw should I get the 12mm X 1.75 pitch or the 16mm?? What's the difference?
Old Nov 15, 2010 | 10:52 PM
Fazz73jr's Avatar
pro 5.0 here. love it
Old Nov 15, 2010 | 10:53 PM
Shadow1999's Avatar
MGW ftw.
Old Nov 15, 2010 | 11:33 PM
97CamaroZ28's Avatar
I just installed my Mgw shifter and it is great much better than the factory hurst. The 12mm is if you want to use one of their shift ***** and the 16mm is if you want to reuse the factory shift ****.
Old Nov 15, 2010 | 11:48 PM
my95LTwon's Avatar
I'll throw up a +1 for B&M ripper just to mix things up a bit. I havent used any other aftermarket shifters....but it works great for me. I would have to agree that it's just a matter of personal preference and you'll just have to see which one feels good for you. I'm pretty sure whatever you buy is going to be better than stock tho. It should be fun trying them all out
Old Nov 16, 2010 | 12:11 AM
SKZ28's Avatar
Yeah, another +1 for the B&M Ripper. I haven't driven another 6-speed f-body since buying mine so I can't really compare it to anything else, but I really like the B&M. I have never missed a shift
Old Nov 16, 2010 | 12:35 AM
  #32
SuperSport01's Avatar
+1 for Hurst billet here.. along with my 2" extended shift lever.
Old Nov 16, 2010 | 10:27 AM
  #33
ffrh911's Avatar
Ok what about other brand shift *****? And I just looked on mgw site you cat get a **** for the shifters for out cars, it's says 'comming soon' I just want a nice black ball with white 1-6 and R on it. So I should get 12mm for any aftermarket ****?
Old Nov 16, 2010 | 10:57 AM
  #34
TDP's Avatar
TDP
Another Vote for the Hurst Billet Plus. I've had 7 different f-bodies in the past and have had just about every shifter on the market. The Hurst Billet was my all-time favorite.
There is no need to have shift stops or an adjustable shifter base, like the B&M or MGW. It just leaves more room for error. For example, if you reverse the washers on a Ripper shifter, then you'll be punching your HVAC controls every time you hit 3rd gear. effin stupid IMO lol
Also, by the way the T56 is designed, there is no need to have shifter stop bolts. The only good use for shifter stops that I can see would be on an old-school manual tranny with external linkage. The Hurst Billet is the only shifter that I know of that doesn't have all this BS on it.
Old Nov 16, 2010 | 11:44 AM
  #35
z28oc91's Avatar
Originally Posted by MTBSully
sorry to be off topic here but does anyone know if the stock hurst shifter (that came on the ws6/ss) is any different from the aftermarket hurst shifter that you would normally purchase?
ive aske that question and people have told me yes, if you buy an aftermarket one you will defitantly notice a difference
Old Nov 16, 2010 | 05:38 PM
  #36
For that you should get the 16mm thread and get the hurst ball that's made for our cars. That's what I have
Old Nov 17, 2010 | 09:17 PM
  #37
94lt105's Avatar
Originally Posted by MR2liter
I love my pro5.0 with UMI short stick.
My exact setup and I love it! That would be my recommendation!
Vince
Old Nov 19, 2010 | 08:57 AM
  #38
Shadow1999's Avatar
The MGW does not have shift stops and i don't believe my base was adjustable in any way. I guess if you really needed to, you can turn the shifter offset for custom installs? Took me longer to get the console off carefully than it did to take the old shifter out and put my MGW in and have loved the feel of it since.
Old Nov 20, 2010 | 12:40 AM
  #39
ffrh911's Avatar
any tips for the install? I'll be doing it at the same time as my new tsp true duals and headers
Old Nov 20, 2010 | 12:55 AM
  #40
ffrh911's Avatar
Too late
