squealing trans/clutch
Old Dec 24, 2010 | 12:33 PM
jetaws6's Avatar
Default squealing trans/clutch
Well I just reinstalled another monster stage 3 clutch after the first one broke under warrenty after 800 mi.
Once I started it I let it idle for about 10 minutes then took it on the road and drove fine for the first mile or so and then something started squealing inside the the bell housing or trans.
I shut the car off looked under it to make sure nothing was leaking started it up and it didnt make a noise for about ten seconds and then it started again.
It also only happens when I am in neutral, idling, or the the clutch is engaged
Anybody have a suggestion? I know some people say beat on it becuase its glazed but its a brand new clutch
Old Dec 24, 2010 | 01:16 PM
Greekey's Avatar
Your clutch is making a noise when the car is in neutral?
Old Dec 24, 2010 | 01:20 PM
jetaws6's Avatar
Might not be the clutch it might be the trans or something else maybe a bearing? I dont know
Old Dec 24, 2010 | 01:26 PM
Greekey's Avatar
Go to your car right now. Make sure shes up to operating temperature. With the car in neutral, take your rpms up to 5k rpms and see if your car creeps forward. Did you replace the pilot bearing, slave cylinder, throwout bearing?
Old Dec 24, 2010 | 01:32 PM
jetaws6's Avatar
stood still
Old Dec 24, 2010 | 01:46 PM
jetaws6's Avatar
replaced slave and I think the pilot
