Tickshift master cylinder question
Old Jan 1, 2011 | 04:34 PM
mylittlez06's Avatar
Default Tickshift master cylinder question
I just bought the master cylinder and I want to install it today....it says nothing in the instructions about bench bleeding it....I obviously cant call the company cause its saturday.....basically do I have to bench bleed it first?
Old Jan 1, 2011 | 04:37 PM
southernculture's Avatar
yes you should bench bleed it.
Old Jan 1, 2011 | 06:21 PM
RedRallyeZ's Avatar
I would
I put mine in without a real bench bleed and ive been struggling for awhile now trying to get the last little bit of air out of the system. I am going to have to take mine out and give it a shot once it warms up, but youll be very happy you bench bled.
Old Jan 1, 2011 | 06:52 PM
NVR_SPDS's Avatar
I installed mine without bench bleeding it at all. No issues what so ever.. Just pumped the **** out of it, and used the bleeder screw. It came out great.
Old Jan 1, 2011 | 06:55 PM
ok thanks guys im gonna bench bleed it
Old Jan 1, 2011 | 06:59 PM
deelong4002's Avatar
You can get away without it, but it's not worth it. It will save you a ton of time in the long run
Old Jan 1, 2011 | 09:53 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I had to bench bleed mine to get the pedal feel I wanted.
Old Jan 2, 2011 | 02:11 AM
I just installed it....it was def a pain in the *** to put in lol.....I bench bled it till fluid started coming out, to bad I cant drive it around or adjust it till spring.....I ****** hate ohio LOL
Old Jan 2, 2011 | 02:26 AM
Captain_Stabbin's Avatar
speed bleeder is the way to go.
Old Jan 2, 2011 | 02:30 AM
yeah I bought one of those too....it saved my life
Old Jan 2, 2011 | 02:40 AM
yea i like it, dont have to get under car to bleed it
