Soft Pedal
Old Jan 4, 2011 | 05:29 AM
airattack111's Avatar
Default Soft Pedal
I just installed a new master cylinder on my car yesterday. Bolted up the line and filled with fluid. I let it gravity bleed until it started dripping, then proceeded to pump-hold to the floor-crack the bleeder. Did that a few times and didn't get much pedal pressure. I then stuck the mity vac on at 12hg and it pulled up some bubbles, gave the pedal a little pressure but still mushy.
I continued bleeding traditionally and with the mity vac, and the clutch pedal is softer than it was before I took my old leaking master off. and engages/disengages horribly. Is there a secret to getting all the air out?
Old Jan 4, 2011 | 06:55 AM
silversrtman's Avatar
did you pump the pedal while you had the mity vac on it?
Old Jan 4, 2011 | 07:44 AM
japsw20's Avatar
Same problem here, I pulled the trans an replacing clutch and slave to see if it fixes it
Old Jan 4, 2011 | 06:54 PM
Yes.
My clutch is only a year old with 15,000 or so miles. As well as the slave. Never leaks fluid or anything, reservoir stays full and clear, but pedal and engagement is terrible.
Old Jan 5, 2011 | 10:16 PM
somZ2801's Avatar
I had same issue mushy peda after master and slave and clutch install l. And a friend said to just take the mighty vac and pump it all the way up and leave it for a while 1/2 hr. and then check it. and it pulled all the air out doing it this way. I had also tried just pumping it to 12 because i heard it would screw up the master any more than that. Mine is fine for over a year now no problems and great pedal engaugement. Just my experience.
