Slave is blown...now what?
1. no clutch pedal pressure
2. damp area on bottom of bellhousing
3. fluid in reseviour seems at ok level?? (i dont get this part)
I'm logically assuming that my problem is the slave and not the master, but oh well. Im planning to replace everything with LS6 components when replacing the slave since its such a PITA to get my trans down due to the awkward placement of the drivetrain in my car ('67 camaros werent designed to have LS1s apparently).
Questions:
1. Do I need to purchase an LS6 slave, or just the updated fbod version, or is it the same one?
2. Can I use the LS6 clutch disk with my stock pressure plate and flywheel?
3. Should I replace the master cyl. as well?
Questions:
just buy the Z06 clutch package
you may not need the 01-02 master with the ZO6 clutch, only if you got have hydraulic problems after everything has been properly bled,
Beauty job putting an LS1 in a 1st gen Camaro BTW.
