Confusion on bleeding clutch.
Open the valve
the clutch will push the fluid out.
close the valve and let the pedal up.
Pump it a few times and do it again.
Make sure you dont' run out of fluid in the reservior.
Tom
Open the valve
Tom
Thanks, I did it that way and also tried the "leave the clutch up, open the valve. Depress the clutch leaving it to the floor, closing the valve." and the pedal didn't seem much different. Worked basically the same but it seemd to force more fluid out.
