T5 Tranny Problems. Need Help!!!
So what can cause all of this? Shift linkage? Shift fork? Is this something I can fix myself? if not, what should I expect to pay to have it fixed?
Any advice will be greatly appreciated.
Your 2nd gear issue could be beat-up gear/synchro slider teeth (which mesh together and sometimes clash together on a mis-shift) which could be the effect, rather than the cause.
Except for setting bearing preload being required on a T5 build (some T56s can be put back together without bearing replacement,) they're about as much work to build. Not bad.
T5s have basically similar shift rail / fork / pad issues to the T56. Pads can crack. Forks can break. But those are then the cause and the effect is the popping out of gear, which becomes damage that must be replaced with new parts.
I have a reverse idler gear for T5 I've had sitting for a while if you do it yourself. Yours is probably chewed.
jmd: How much do you want for that idler gear. I can live with 2nd gear popping out of gear but not reverse. It's bad enough that I can barely get the car to move before it tries to pop out on me.
