Looking for new clutch
Old Mar 3, 2011 | 10:22 PM
Z28LS1camaroguy's Avatar
Default Looking for new clutch
Well im in need of a new clutch and im wanting to replace the flywheel while im in there aswell, I plan on doing heads and cam here soon, going to go with the MS4 cam and LS6 2.5 heads package and need a clutch that will perform. I have right now a ram stage 3 clutch in that needs to be changed and im looking at this clutch set right here http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=2919{11}1111, has anyone ever used this clutch or should i stick with ram?
Old Mar 3, 2011 | 11:22 PM
NightmareTA's Avatar
I'm going with a Textralia OZ700 since I have read nothing but awesome reviews on them. With that said, I've also heard great things about monster clutches as well. I would think you'd be fine going with a monster stage 3. Seems to be about the norm for a H/C LS1 build.
Old Mar 4, 2011 | 12:12 AM
Greekey's Avatar
Monster Stage 3? haha...Man that's the clutch I have, as well as many others. IT KICKS ***. I believe its monsters number one selling clutch. Get it NOWW!!!
Old Mar 4, 2011 | 12:46 PM
SNLPerformance's Avatar
That clutch will easily hold your future plans, we actually have a new 11" carbon/organic that would be more than enough too. Give me a call at 817-750-2000 if you have any questions, Chris
Old Mar 4, 2011 | 08:39 PM
droppedls1z's Avatar
I thought you said in the link below that organic was a weak link???
Post #3
"[QUOTE=SNLPerformance; A dual friction clutch is only as strong as it's weakest link, the organic side in this case."[/QUOTE]
https://ls1tech.com/forums/manual-tr...bang-buck.html
Old Mar 5, 2011 | 03:48 PM
im just looking for a clutch that will last and take a beating, while also get me home. I liked my Ram but i want a good package with a new flywheel, throw out bearing, master slave cylinder and the clutch of course, just got a aluminum driveshaft from a fellow member now just want to fix my slipping clutch problem with a bad *** clutch that will match my heads/cam that i will be doing.
