New clutch problems
Old Apr 4, 2011 | 12:27 PM
Bird.is.Word's Avatar
Default New clutch problems
I just installed a new clutch and flywheel on my 99 Trans AM with a T56. The clutch kit is an Exedy OEM replacement kit. After getting the new kit installed and bleeding the system, the car would not go into any gear while running. The throwout bearing that came with the kit had some play in the plastic ring around it so I bought a new throwout bearing and slave cylinder to eliminate those possible problems. The car still has all the same issues even after installing the new parts and bleeding the system again. The only way I could get it in gear was by turning the car off and putting it in gear. While running, the clutch stays engaged and will not disengage when I push the pedal. I've been searching the forums about this problem and only found one thread that did not have a sure answer to the problem. I'd greatly appreciate any advice I can get.
