Bleeding clutch. Noob question
Old Apr 14, 2011 | 02:24 PM
chevbon's Avatar
Default Bleeding clutch. Noob question
Cant find the valve on my t56, HELP!! PS its an LT1
Old Apr 15, 2011 | 12:44 AM
Sargeant Sh!tbag's Avatar
You will not be able to see it. You will just have to reach up there, find the hole and use the correct socket to loosen and tighten it. I have used the Tick remote bleeders after fighting with the bleeding under the car one too many times.
Old Apr 15, 2011 | 01:05 AM
jr's camaro's Avatar
if you go under the car you can feel for it but trust me when i say it is going to be a pain to bleed it.......the best and easy i found of doing it is to buy a mighty vac and and stick it in the master cylinder and put the mighty vac up too 12psi and then hit the clutch until there are no bubbles come out the line........then release the mighty vac and try it out..................hop this helps
Old Apr 15, 2011 | 06:44 AM
Regulator's Avatar
Did you have to pull the trans out of the car to install the remote bleeder?
Old Apr 15, 2011 | 11:13 AM
chevbon's Avatar
Pulled out the slave. Looks like Im gonna need a new clutch anyway!!
Old Apr 15, 2011 | 02:13 PM
z28_theantirice's Avatar
I just ordered MityVac, I am interested to see how much air I can pull out my my hydraulics.
