adjustable master ?'s
Old Feb 21, 2004 | 01:04 PM
JimMueller's Avatar
Default adjustable master ?'s
Ever since I had my last clutch installed, I felt the pedal was too high. So I finally got under the dash with a sawzall and pliers
Anyway, the first attempt I moved it too close to the floor, but it was still disengaging well. However, I noticed the top of the pedal travel had no resistance at all. As I gradually brought it back up most of it went away.
Where is your clutch pedal in relation to your brake pedal? Even, higher, lower?
