Clutch Help
Give us a call, we've got our clutches on sale right now till the end of the month!
http://www.specclutch.com/cars/Chevy/Camaro/2000/Single
Keep in mind that your description doesn't inherently mean the clutch is slipping. When you feel the loss of power do you notice the RPM's increase without the car gaining any speed? If so then that is clutch (or tire) slippage. If not, then you may be seeing a problem with the tune or with fuel delivery as mentioned by Bandit. It could be a fuel-filter issue, bad gas, or even an injector problem (along with other possibilities). Let me know if you have any further questions and I will be happy to assist you. Thanks,
