clutch is loosing pressure
Old May 28, 2011 | 06:36 PM
Karl101's Avatar
Default clutch is loosing pressure
first of all i have a 2000 TA with stock everything.... my clutch is loosing pressure and i don't know if it is the master or the slave cylinder. example is when i'm at a stop sign and when i have it in gear with the pedal pushed in, the car will try to take off after a few moments. and also it will get stuck in 1st or reverse because i can't pump the pedal.
Old May 28, 2011 | 06:59 PM
Zmg00camaross's Avatar
If there no leak under the trans. I would look more of the master cylinder leaking internally.
Old May 28, 2011 | 08:33 PM
wrd1972's Avatar
Maybe the pressure plate bolts are backing out.
