trans mount?
the mount raised the trans about 1/4" and now the shifter hits the center console when trying to get it into reverse.
does someone make the exact mount for a 01 ss camaro 6m?
I've been running the ES trans mounts that way for probably 10yrs, and I only replace the first one a couple of yrs ago because the metal in the urethane eventually stretched the urethane allowing it to rotate when you tighten up the bottom mount bolt.
