Split a flywheel in two.
Old Jul 24, 2011 | 09:35 PM
t-1's Avatar
t-1
Default Split a flywheel in two.
I have.. errr had and ram twin disk clutch with their flyhweel. Couple days ago I was under power and all of a sudden it hits the rev limiter. Figured it was the clutch letting go. So I took it apart last night and the flywheel had seperated from the "hub" area or flange area were it bolts to the crank. A perfect circle around all the bolts. Maybe two thousand miles on it. Anyone have this problem??? Brand new gm flywheel bots torqued in a star patternt with a good torqu wrench. Launch maybe 8 times in its life. I was only at 11 pounds of boost so maybe 800whp sae so 650 real number.
Old Jul 25, 2011 | 10:38 AM
SPEC-01's Avatar
I would give RAM a call. They will want to know about this and will likely be able to help you.
Old Jul 25, 2011 | 11:57 AM
t-1's Avatar
t-1
Cool, Ill call em tomorrow. I was just a bit curious if I was the only that had managed to do this.
Old Jul 25, 2011 | 12:41 PM
99SSJarhead's Avatar
Get a picture, this would be an interesting sight to see
Old Jul 25, 2011 | 12:46 PM
SAchris's Avatar
This ^^
Chris
Old Jul 25, 2011 | 06:11 PM
SNLPerformance's Avatar
I'm with Spec-01, this could potentially be a serious issue.
Old Jul 25, 2011 | 06:31 PM
xxrillixx's Avatar
Id love to see this...
Old Jul 25, 2011 | 06:37 PM
Zmg00camaross's Avatar
This is why I would recommend a quicktime bellhousing you just never know. Could have potentially destroyed your car and hurt you also.
Old Jul 25, 2011 | 06:39 PM
bigj2717's Avatar
