simple gravity bleed
Old Aug 20, 2011 | 05:46 PM
bobodog's Avatar
Default simple gravity bleed
a guy i know whos a mechanic suggested a easy way to flush the clutch fluid by yourself. you losen the bleeder valve and let drain steady adding fluid to the resavior as it drains until it is clear coming out.no pumping the pedal is necessary. Tighten the bleeder valve then top off the resavior. i tried it and have had no issues with air in the lines. it did improve the fading issues i was having.this method is only for flushin the fluid not bleeding air.
