Need some help with the trans
What I've noticed:
1. The clutch holds well, it will spin the tires slightly in third at ~70mph wot. There's no slippage that I can tell.
2. Car will occasional have a very slight grind when going into third during moderate driving (~2500 rpm shifts) Only happens maybe once every 50 shifts.
3. Car has gear noise in the trans at idle with the clutch engaged. If I disengage the clutch the noise stops. Car will also make whirring/gear noise in 1st-4th gears. It's not overly loud but you can hear it. It's louder when the car has reached full operating temperature.
4. If shifting into second at moderate to heavy throttle (4000rpm shift) it sounds like the clutch may slip a little going into second. It's a rough sound as if you would rub two brake pads together or something. Or like tires spinning slightly in small gravel/sand. This is also the same sound/feeling as the "roughness" referred to above if you try to take off too quickly. My guess is just typical clutch slippage.
I haven't tried a full shift from 1st to 2nd yet. Kind of scared since I stripped the teeth off of my ring/pinion in my old car last time I did that. I know I have probably 100rwhp less than I did then plus 3.43 gears opposed to 4.10. But still not wanting to spend the money on a new set of gears this early into ownership.
So what's the consensus? I'm going to change the trans fluid here soon to see if it clears up the noise and figure I'm closing in on a new clutch. I'm just hoping I don't need a rebuild.
