if the front seal is broken, does it require to disassemble?
Old Oct 2, 2011 | 07:43 PM
stephen4036's Avatar
Default if the front seal is broken, does it require to disassemble?
front seal could be broken, cant find the leak but we all think its the front seal.. can you just pull the trans out and have it replaced? or does it require a disassemble? its a T56.
Old Oct 2, 2011 | 08:44 PM
wrd1972's Avatar
Tranny must be pulled and the front face must be removed. Fairly easy to do, just watch the front 3/4 blocker ring when putting it back together and dont force anything.
Old Oct 2, 2011 | 09:10 PM
jmd's Avatar
jmd
https://ls1tech.com/forums/manual-tr...put-shaft.html
